TwinTurbo.NET: Nissan 300ZX forum - My NA..
Subject My NA..
Posted by Cjw3 on October 26, 2013 at 11:15 AM
  This message has been viewed 201 times.
In Reply To Re: Re: Re: Re: Re: Let's see if I can help: posted by wild_maxx on October 25, 2013 at 09:53 PM
Message I ended up with Unknown heads on my NA re-haul.. the Drivers side was 1/2 tooth off, and the P/S was 1 tooth off.. the Pass Side was easy to fix.. just restamp the dot.. and move the Intake Cam on the Sprocket.. the Drivers Side I chose to Re-Drill the Alingment Pin 180* off, -the Needed Offset on the Exhaust Gear.. then just Adjusted the Intake Cam on the Cam Gear..
Drivers Side
I was also lazy in setting up the Dial Indicator.. so I built a Fixture to make the job faster..
It reads the cam 180 out.. but that is a no brainer..
Cj
